It is currently Sun Sep 14, 2025 5:07 pm
PostPosted: Sat Jan 12, 2008 12:07 pm
Well, I finally got my neck bolt system going.
I looked at 4 different brands and settled on the steel inserts from Mcfeely's. The reasons I went with this insert was that it has a very agressive thread,it has a hex shaped hole to drive it in with(I use their driver) and I like the idea of steel(stronger) than the brass ones.
First I drilled to 9/32" holes through the neck block to allow a little wiggle room for the 1/4" bolts:
Then I use a transfer punch (great tool!)to mark the exact location of the hole centers in the headblock to the neck:
Here's the whole set of punches:
Here's the one I am using:
Here it is inside the guitar-simply push it with your hand and it transfers the mark to the neck:
Next I drill the holes for the inserts-as you can see there is already a 1/2" dowel inserted in the heel for the inserts to bite into. I am using my drill press for this operation.My drill press has a unique feature-the table turns horizontally so I can drill the holes with precision:
After I drill the holes to a little deeper than the insert I chamfer the holes.
And finally I screw the inserts in using a little thick CA with a cordless drill on low being careful to go in squarely.
I really like how this is working out-everything lines up nice and the inserts aint comin'out!!
PostPosted: Sat Jan 12, 2008 12:20 pm
Nice, simple procedure. Thanks, Brad!
PostPosted: Sat Jan 12, 2008 12:23 pm
Very well done Brad and that guitar looks pretty cool too!!!  Many thanks my friend!
PostPosted: Sat Jan 12, 2008 12:25 pm
Thanks Brad.....Great job .. ....I am going to use this type of bolt on system on my next build.....Thanks again
PostPosted: Sat Jan 12, 2008 2:23 pm
Love the transfer punches, where'd you get those? I'd like to get them for the same exact purpose
PostPosted: Sat Jan 12, 2008 3:21 pm
Tery,
They come from Harbor Freight-$9.99 for the set!!
PostPosted: Sat Jan 12, 2008 7:45 pm
Last Name: Abercrombie
Brad-
How do you align the neck and hold it in place while you are using the transfer punch? I've found that this is a hassle without a mortise and tenon to help with alignment.
Any tips?
PostPosted: Sun Jan 13, 2008 3:29 am
John,
Funny you should mention that, because I forgot to post the picture of that step-so here it is.
What I did was clamp the fretboard on the neck with a couple of spring clamps and lined up the center line- I simply held it there while I pushed the transfer punch in:
PostPosted: Sun Jan 13, 2008 4:25 am
This is all cool, and it's very much how i did it for years, even down t the drill press and punches. I finally just made a pair of simple jigs with drill bushings, though, and can build the neck and body separately, and everything lines up in the end. And it means my necks are  now interchangeable/replaceable....
But you can also clearly see why I moved away from the inserts and toward the hanger bolt. Not a whole lot of that dowel is left. Yes, the inserts are in no danger of being pulled loose, that will never be the issue. But the heel can crack too easily from an impact, if you carve it as dainty as I try to do mine... The hanger bolts leave a lot more dowel, and leaves a much stronger heel area. Also simpler to install.
PostPosted: Sun Jan 13, 2008 4:34 am
Mario, your jig is very cool. I saw it on your website a year or so ago and
copied it. Hope you don't mind. Works great!
PostPosted: Sun Jan 13, 2008 5:00 am
Yes,Mario-I do see your point and I plan on using the hanger bolt system on one of my next guitars.
PostPosted: Sun Jan 13, 2008 6:07 am
If I didn't want to share, I wouldn't show those things on my site; feel free to use anything you see. It's what I do when i visit others' sites <bg>
Do give the bolts a try. Don't get me wrong, the inserts served me well,  and they'll serve you well also, but I did have two necks crack at the insert hole after accidents. Neither one opened up(thanks to the dowel), and both repaired perfectly with a little hide glue and have held up for years now, but it did make me look at it all to see if it could be stronger.
PostPosted: Sun Jan 13, 2008 6:15 am
[QUOTE=grumpy]If I didn't want to share, I wouldn't show those things on my site; feel free to use anything you see. .
Mario..Where can I find this site to have peek....Thanks larry
PostPosted: Sun Jan 13, 2008 6:19 am
That there's the secret...
PostPosted: Sun Jan 13, 2008 6:35 am
Larry,
It's www.proulxguitars.com
Great website!
PostPosted: Sun Jan 13, 2008 6:53 am
First name: stan
Last Name: thomison
City: branson
State: mo
Zip/Postal Code: 65616
Country: united states
Mario, I remember you use jig that fits into your truss slot for markiing and drilling holes into the neck. What I can't remember, and don't have the issue of the Guitar Maker or article in handy (been moving and lost a box of good stuff, even planes and tools)is jig that marks the position and for marking and/or drilling holes into body. Is that on your site, if so keep missing it or if not could you sometime show this. I am still very interested in the butt join . TIA
PostPosted: Sun Jan 13, 2008 6:55 am
First name: stan
Last Name: thomison
City: branson
State: mo
Sorry hit wrong button before finish. Brad, good article.
Thanks Brad,,,,
Mario.....Holy Moses....Is that a pic of you on the web site...Sure, you are just a young whipper snipper....With your vast knowledge and wisdom I had you pictured like this....
<laughing>....<Running>....<Ducking>
PostPosted: Sun Jan 13, 2008 7:25 am
Just 'cause he's grumpy,doesn't mean he's old....
PostPosted: Sun Jan 13, 2008 9:34 am
That photo's also 6 years old <g> Still no grey, and no hair loss, though.... I started at this young enough. The site is in the midst of a complete makeover. It'll look VERY different once I get 'er done.
Body jig looks the same as the neck one, without the truss rod index part. I use fine lines to line it with the top's centerline and the back's... Really simple. One clamp via the soundhole. I have 80 grit paper glued to it so that it doesn't skate around under light clamping, BTW. That's about the only "trick".
PostPosted: Mon Jan 14, 2008 7:40 am
Brad, great tutorial thank you for taking the time to document, explain and share.
I see that you use a 1/2" dowel for the reason explained. Would you also recommend using a 1/2" dowel if you used a neck tenon/body mortise joint like many do?
Mario, cool jig on your website for lining up the drill bit for your neck joint.
Guys, Mario is actually a lot older than he appears on his website. Living as far north as he does, has a preservative effect <bg>
PostPosted: Mon Jan 14, 2008 8:13 am
Anthony,
I don't think people use the dowel on the tenon style because there is not enough wood there.
Collings uses a dovetail shaped tenon with a dowel in it with the hanger bolt system.
PostPosted: Mon Jan 14, 2008 11:45 am
PostPosted: Mon Jan 14, 2008 4:23 pm
Anthony and Brad, I use a 1/2" dowel on my tenoned necks. Without it, the sides of the tenon tend to blow out when installing the inserts, but having the dowel in the tenon stabilizes the tenon and actually the insert only screws into the dowel as it's less than 1/2" in diameter (drill size that is).
I want to give the hanger bolts a try, should work out great with a mortise and tenon too.
PostPosted: Tue Jan 15, 2008 12:55 pm
Last Name: Ball
How ironic it is that the hanger bolt neck attachment has been a mainstay of banjo builders for so long
Users browsing this forum: bluescreek and 72 guests
